Adding tasks inside table cells not working
Version 1.0 (1208):
I tried to add a task inside a table cell: cmd T - did not work. This would be a killer feature for task/project management.
Hi there,
thank you for your feedback, unfortunately, markdown tables don’t allow list or task inside the cells, so until the format adds support for those we can’t add it.
Best.
