Testing version: 0.1 (1648)
What were you doing: Making multiple numbered lists
What feature did you use: numbered lists
What happened: I want a list of references from the bibliography of a paper I’m reading. In Bear, I have this:
7. Eric Brockmeyer, Ivan Poupyrev, and Scott Hudson. 2013. PAPILLON: Designing Curved Display Surfaces with Printed Optics. In Proceedings of the 26th Annual ACM Symposium on User Interface Software and Technology (UIST '13). ACM, New York, NY, USA, 457–462.
55. Thiago Pereira, Szymon Rusinkiewicz, and Wojciech Matusik. 2014. Computational Light Routing: 3D Printed Optical Fibers for Sensing and Display. ACM Trans. Graph. 33, 3 (June 2014), 24:1–24:13.
81. Karl Willis, Eric Brockmeyer, Scott Hudson, and Ivan Poupyrev. 2012. Printed Optics: 3D Printing of Embedded Optical Elements for Interactive Devices. In Proceedings of the 25th Annual ACM Symposium on User Interface Software and Technology (UIST '12). ACM, New York, NY, USA, 589–598.
(enclosed as <pre>
to prevent the forum from incorrectly renumbering)
And it works properly: the extra line between each item seems to make each one its own list so the numbers are preserved.
In the beta, I get this:
What did you expect to happen: the empty line in between should reset numbering
