Most apps these days auto-save the file you’re working on (including Bear ), and so I’ve slowly untrained my habit of saving files. I noticed that Panda does not auto-save the file.
Was this intentional, or just not implemented yet? Would be great if changes were to auto-save, either immediately or after a few seconds delay. I realized I hadn’t saved a file that I had been typing in all day — a simple crash or restart would have lost all those changes.
Basically when I change a file it shows “Edited” in the title bar of the window. If I hit Command+S, then that goes away. Typically in editor apps (eg VSCode etc) such an indicator in the top tab shows you it’s not saved yet
Oh, I see! On macOS, that indicator doesn’t mean that the file is not saved it just means that it wasn’t saved directly by you. The file is auto-saved even if you don’t do it (you can quit the app at any time and your content won’t be lost).
That’s related to how the macOS file versioning works, you can for example revert the file to the latest saved version (the one you manually saved, not the autosaved one) or browse the file history (all the version in the history are the one saved by you).
This is not something that was designed by us, it’s how the standard document-based apps work (TextEdit, Pages, Numbers, etc…).
Thanks! Now that you explain it, it makes sense. So it’s a macOS feature, not a Panda feature then? In that case I suppose no action is needed. Seems like a confusing thing though, I suspect I won’t be the only one who might wonder this regarding Save behavior.
