I’d like to suggest to have a side panel that you can show/hide for backlinks that can be persistent unless hidden/collapsed instead of the popup under the i panel. The popup is a nightmare to dig through backlinks when you have a lot tied to a note.
The „side panel“ is going to come, maybe in the next beta.
See some screenshots here:
The popover is persistent if you detach it.
I didn’t know you could do that! Thanks.
This is exactly what I was hoping for! Thanks!!!
