Backlinks view get's stuck (Mac)
Version 2.0 (10936). Mac.
Issue
Backlinks get’s stuck on showing backlinks for the first note you show it for even after you navigate to other notes.
Steps to reproduce:
  1. Open fresh copy of Bear (i.e. quit it if already running)
  2. Select a note if not already selected (easiest to demonstrate if you know what backlinks a note has).
  3. Open the info panel and select backlinks
  4. Change note and check the backlinks panel again and notice how it never changes.
From what I can tell this problem stays for the duration of running the Bear app and the only way to clear it is to re-start Bear.
Same issue here. Also Mac 10936.
I also have this issue (Mac 10936)
Same issue (Mac 10936)
Good Morning and thanks for reporting this. A fix for this glitch will be available with the next update.
Same issue (Mac 10936) - glad a fix is coming
Thank goodness the backlinks ARE working on iPadOS.
Previously reported with no response here:
Are you saying you still have this issue with the last build?
I posted that before you released build 10984. At first glance, this backlinks tab display/disconnect issue seems fixed in this build.
