Testing version: 2.0
What were you doing: I was testing the export from a single bear 2 file to my desktop, then importing into Bear 1.
What feature did you use: Desktop icon while using Stage Manager
What happened: I notice that Bear 1 now has the sunglasses icon along with Bear 2. Note that the icons are correct in the Doc. I only see the following behavior in Stage Manager. Both have sunglasses in the side stage manager. Icons are correct in the doc.
What did you expect to happen: I expect that Bear 1 will not have the sunglasses and that Bear 2 will have sunglasses. This is a handy way to differentiate the files since I have the two versions next to one another in the doc.
Again, I only note this in stage manager
