Bear 2.0 (10934) crash on startup
Testing version: 2.0 (10934)
What were you doing: Starting the application after it had been updated
What feature did you use: Nothing, Bear wont start
What happened: Nothing, Bear wont start
What did you expect to happen: Bear should start without crashing
Same for me. M2 MacBook Air. Error message is that Bear quit unexpectedly.
Hi folks, we’re looking into that, we’ll update asap.
Wow, that was fast! All good now, nothing lost.
That fixed it! Thank you!
