Bear 2.0 No Control-click Drop Down Menu
Version 2.0 (10641)
Attempting to delete note in the Note List
CTRL-click
Nothing
Drop down menu with option to delete file in list (CTRL-click OK within a note)
Thanks for reporting this. We are investigating the issue.
Testing Version 2.0 (11015) on macOS 13.2.1. Using MacBook Pro M1 + trackpad.
I think this issue is the same one as I noticed earlier today too. I was Control + clicking the macbook’s trackpad on the notes list, expecting to see a menu. My observations:
  1. I can get the menu to appear if I very carefully Control + click exactly on the date modified text.
  2. If I have a second note open in a new window, the menu appears as you’d expect by clicking anywhere on the note row.
I can recreate your examples every time. Nicely spotted!!
