Bear 2 Beta Zoom Functionality
In my limited usage so far, Bear 2.0’s functionality has been excellent, with migration working perfectly. One major feature I use often has changed quite dramatically, however. The Zoom function (CMD +/-) now updates all open Bear windows if you have multiple notes open at once. Formerly, the zoom was Window dependent, so you could choose a different zoom level for each window.
I use multiple monitors which often require different zoom levels depending on the task. I love that feature of Bear 1.
I’m wondering if this new zoom functionality is an intentional change? Or simply something that hasn’t been addressed yet?
I too have this question for a very similar use case.
It’s also not performant when I have 12 different Bear windows open, and changing zoom has to update them all.
It would be great if zoom could be per-window again.
