Bear for iOS. Visual glitches when you mix images/drawings with text and vertical scrolling of tables
Testing version: 2.0 (10641)
Hello! :slightly_smiling_face:
The iOS version of Bear has some funny visual glitches when you mix images/drawings with text. Some text lines disappear (they look like empty lines until you tap/select them) and others overlap (as if the line height is set too low).
Also, something strange happens with tables when they are preceded by twenty or more lines of text or several large block elements (font size set by default): they start to scroll vertically, causing the top rows to disappear from view. This table scrolling bug seems like it deserves its own thread, but it causes the hidden text I mentioned above to not appear on tap, but on select. That is, there is a synergy of two glitches.
Here’s what it looks like in action:
And here’s the note I used when making the video:
A new build has just been released. Is it still happening in this one? Haven’t had the chance to test this out but had similar bugs too.
Yes, it is :slightly_smiling_face: So I’ve changed the version in the topic.
Where did you find the link for Bear 2.0 for iOS?
Yup, something wrong in that note. We’re able to reproduce it and we’ll work on it asap.
