Bear sometimes switches to Light Mode Theme in iPad Split View or Multi instances
Testing version: 2.0 (10817) iPad Pro 11” 2nd gen.
What were you doing: Opening multiple instances of bear.
What feature did you use: OS’s 3 dots - elipses button on middle top of screen.
What happened: Adding or changing windows (bear instances) sometimes appeared in my chosen light mode Theme, even though I have set Dark Mode always on in OS settings.
What did you expect to happen: All instances to show same ”Dark Mode” theme as I have selected in Bear settings.
See screen recording below:
PS. My workaround for now is to use “Dark Note” theme both for light and dark OS mode. Works for me since I have Dark Mode alway on, but for others …
