Testing version: Version 2.0 (9695)
What were you doing: Importing files (.bear type)
What happened: In file import dialog (Options), both “Use first line as title” and “Use filename as title” are enabled (checked) by default.
What did you expect to happen: I believe they should be mutually exclusive (as was the case in Bear 1 version), checking one should uncheck the other
Also, “bear” filetype should be also mentioned here in the text? (if this option applies to it)
EDIT: They actually are mutually exclusive after I click on one of them. But original state when opening import window is as attached
