Checbox shortcut
Standard markdown for checkboxes, - [ ] and - [x] doesn’t seem to be working in Bear 2. Should it? Will it?
Yes, Bear 2 works with that checkboxes syntax (it’s not standard MD) but you have to add an extra space after ] for the markers to be valid.
Thanks. Is the extra space really necessary? It seems like an odd extra.
Follows how the editor works with this kind of marker (headers, lists, …), you want to see what you type before it’s replaced by the corresponding symbol (checkbox, header indicator, …).
