Checkbox scrolling bug?
v2.0 (11093)
Trying to check the checkboxes in Bear notes
Checkbox
When trying to check the checkbox without moving the cursor, the page will scroll back to where the cursor is. A bug or by design?
It should stay at where I check the checkbox
No, it’s not by design. Do you mind sharing the note in the video for tests? A markdown export is more than fine.
There you go, exported as markdown.
# Checkbox bug
#bug report#
- [x] Checkbox 1
- [x] Checkbox  2
- [x] Checkbox 3
- [ ] Checkbox lhkjhfskdjfhskd kjhfkdsjhfld kjshdfkjsdhfl kjshfksdjhflk kjshfksdjhfl ksjdfhksdjfh lkjhkljhf lkjhiuewfipu ouwfpowehfkwj ufhwjhfk pouhfkewjhf fkjhewlf kjhfkjl
- [x] Checkbox lhkjhfskdjfhskd kjhfkdsjhfld kjshdfkjsdhfl kjshfksdjhflk kjshfksdjhfl ksjdfhksdjfh lkjhkljhf lkjhiuewfipu ouwfpowehfkwj ufhwjhfk pouhfkewjhf fkjhewlf kjhfkjl
