Coloured tags in code block
Hi users, hi developers,
I’m really looking forward to see Panda get to its final release since it’s really a powerful editor. Anyhow, I wanted to suggest a feature for code blocks: if I write down some HTML tags in normal text, I see it that tags get highlighted. But if I do the same in code block, then every word will get back to grey-colour tone.
I know that supporting code-syntax may be very complicated since there are a lot of programming languages. But I was wondering if there’s any chance to have some basic support for at least the most used ones (even highlighting only the most common commands like HTML tags, if, else, switch and so on).
It would be really helpful for developers writing snippets, notes and software documentation.
Thanks.
You can in Panda:
Just add language code after opening triple back-ticks:
Oh I’m sorry, I didn’t know it was already possible. My bad!
Thanks for the kind replay.
You know what they say, you learn something new everyday Marco!
If you’ve any further queries/ questions about Bear or Panda let me know as i’d be happy to help :slight_smile:
