BornIO
November 13, 2022, 11:03am
1
Testing version :
9803
What were you doing :
Create a bullet list with different indents. Convert bullets to numbers.
What feature did you use :
List and Ordered List
What happened :
The indents/nesting are lost when moving from List to Ordered List.
What did you expect to happen :
Idents and nesting to stay – as it behaves in the stable version of Bear.
trix180
November 14, 2022, 10:25am
2
Yes, the conversion from unordered to ordered list should preserve the list indentations.
Thanks for reporting this bug.
BornIO
December 6, 2022, 9:50am
3
The latest fix is still [partially] broken. Removing the list and re-adding it will lose indentation.
trix180
December 6, 2022, 10:59am
4
I get what you mean but removing the list comes with a compromise in terms of indentation to accommodate the markdown handling of tabs/spaces at the begin of the line.
