Copy Code doesn't copy inline code inside tables
Testing version: Version 2.0 (9803)
What were you doing: copying inline code from table cell
What feature did you use: Copy Code ⌥ ⇧ ⌘ C
What happened: did not copy
What did you expect to happen: copied the inline code inside the table just like both inline and code blocks outside of table.
I figured this is a bug since the inline code is rendered inside the table.
Hi Brian,
yes, We forgot to implement coy code inside the tables. I’ll take care to implement this for next update.
Thanks for reporting this.
Does copy code work within tables now?
