Copy Link To Note with keyboard shortcut
Testing version: 11015
What were you doing: Copying link to note
What feature did you use: Keyboard shortcut ⌥⌘⇧L
What happened: It copied a link to the note with new_window=yes
What did you expect to happen: As the keyboard shortcut in the menu, it would do the same as the menu item (copy without new_window=yes)
Don’t get me wrong, I actually really like having the link with that query param, but it’s not expected and inconsistent so I’d consider it a bug.
Thanks, this will be fixed with next update.
