Crashed when opening an attached PDF
Testing version: 1.0 (2208)
Opening an attached PDF
PDF opened properly in a window but that And crashed and had to force quit (app not responding)
Crash report
Date/Time: 2021-08-27 12:28:18.029 -0400
End time: 2021-08-27 12:28:56.885 -0400
OS Version: macOS 11.5.2 (Build 20G95)
Architecture: arm64e
Report Version: 32
Data Source: Stackshots
Shared Cache: 74867C57-7C81-38D6-BB42-68EC05B7B3CB slid base address 0x183d5c000, slide 0x3d5c000
Shared Cache: 27F6DF85-5F9B-3963-A9A2-9106536EC7F6 slid base address 0x7fff2007c000, slide 0x7c000
Command: Panda
Path: /private/var/folders/*/Panda.app/Contents/MacOS/Panda
Version: ??? (???)
Parent: launchd [1]
PID: 77051
Time Since Fork: 1050s
Event: hang
Duration: 38.86s
Duration Sampled: 5.60s (process was unresponsive for 33 seconds before sampling)
Steps: 56 (100ms sampling interval)
Report threshold: 2.5s
Hardware model: MacBookAir10,1
Active cpus: 8
Time Awake Since Boot: 279900s
Time Since Wake: 2187s
Timeline format: stacks are sorted chronologically
Use -i and -heavy to re-report with count sorting
Heaviest stack for the main thread of the target process:
56 start + 4 (libdyld.dylib + 99376) [0x184065430]
56 ??? (Panda + 27260) [0x10016ea7c]
56 NSApplicationMain + 1064 (AppKit + 14456) [0x1868f7878]
56 -[NSApplication run] + 596 (AppKit + 204364) [0x186925e4c]
56 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1292 (AppKit + 262144) [0x186934000]
56 _DPSNextEvent + 836 (AppKit + 267872) [0x186935660]
56 _BlockUntilNextEventMatchingListInModeWithFilter + 72 (HIToolbox + 196020) [0x18c068db4]
56 ReceiveNextEventCommon + 552 (HIToolbox + 196596) [0x18c068ff4]
56 RunCurrentEventLoopInMode + 292 (HIToolbox + 197248) [0x18c069280]
56 CFRunLoopRunSpecific + 600 (CoreFoundation + 533912) [0x184144598]
56 __CFRunLoopRun + 1728 (CoreFoundation + 537552) [0x1841453d0]
56 __CFRunLoopDoBlocks + 408 (CoreFoundation + 541604) [0x1841463a4]
56 CFRUNLOOP_IS_CALLING_OUT_TO_A_BLOCK + 28 (CoreFoundation + 542000) [0x184146530]
56 ___NSMainRunLoopPerformBlockInModes_block_invoke + 44 (AppKit + 6052480) [0x186eb9a80]
56 __62-[NSDocumentController(NSInternal) _onMainThreadInvokeWorker:]_block_invoke_3 + 172 (AppKit + 6041684) [0x186eb7054]
56 __46-[NSDocument relinquishPresentedItemToWriter:]_block_invoke_9 + 924 (AppKit + 5953212) [0x186ea16bc]
56 -[NSDocument(NSDocumentSerializationAPIs) continueFileAccessUsingBlock:] + 248 (AppKit + 6516172) [0x186f2adcc]
56 __46-[NSDocument relinquishPresentedItemToWriter:]_block_invoke.3226 + 56 (AppKit + 5954488) [0x186ea1bb8]
56 -[NSDocument _revertToVersion:preservingFirst:error:] + 140 (AppKit + 5806144) [0x186e7d840]
56 -[NSDocument performSynchronousFileAccessUsingBlock:] + 108 (AppKit + 4059244) [0x186cd306c]
56 -[NSDocument(NSDocumentSerializationAPIs) _continueCurrentFileAccessDuringBlock:] + 248 (AppKit + 6516876) [0x186f2b08c]
56 __53-[NSDocument performSynchronousFileAccessUsingBlock:]_block_invoke + 36 (AppKit + 4059424) [0x186cd3120]
56 __53-[NSDocument _revertToVersion:preservingFirst:error:]_block_invoke + 300 (AppKit + 5806512) [0x186e7d9b0]
56 -[NSFileCoordinator coordinateReadingItemAtURL:options:error:byAccessor:] + 120 (Foundation + 304864) [0x184ed46e0]
56 -[NSFileCoordinator(NSPrivate) _coordinateReadingItemAtURL:options:error:byAccessor:] + 756 (Foundation + 305660) [0x184ed49fc]
56 -[NSFileCoordinator(NSPrivate) _blockOnAccessClaim:withAccessArbiter:] + 400 (Foundation + 307596) [0x184ed518c]
56 _dispatch_semaphore_wait_slow + 132 (libdispatch.dylib + 19180) [0x183e98aec]
56 _dispatch_sema4_wait + 28 (libdispatch.dylib + 17448) [0x183e98428]
56 semaphore_wait_trap + 8 (libsystem_kernel.dylib + 3600) [0x18400ce10]
*56 ??? (kernel.release.t8101 + 515700) [0xffffe0007c95e74]
Hi there,
Thank you for reporting the above, and for providing all the relevant information.
May I ask, is this still occurring for you? Was it only one particular PDF, or does it/did it happen with other PDFs?
Hi,
I am not able to reliably produce this bug. It hasn’t happened again since I first reported it. I will let you know if I can reproduce :slight_smile:
best,
Mussie
