Crashes when trying to toggle info panel
Testing version: Version 1.0 (2208)
What were you doing: View > Hide Toolbar; then View > Toggle Info Panel
What feature did you use: Info Panel
What happened: Application Crashed
What did you expect to happen: Either disable “Toggle Info Panel” when toolbar is hidden, or Show the info panel briefly.
More information:
MacOS: 10.15.7 (19H524)
Hardware: MacBook Pro (16-inch, 2019)
Hi there,
Thank you for reporting the above.
This is something we’re aware of, investigating, and hope to have a fix for in future updates!
I can still produce this issue, is it still being worked on?
Hi there Eleanor,
This should be amended in the newly released version of Panda.
Give it a go and let us know what you think!
