Create Note shortcut is working great
I have a Shortcut that uses the Create Note action. It’s working flawlessly with the beta app.
Wayne();
P.S. I expected that I would have to convert it to Open-URL and use the bear2 x-callback schema. So I was pleasantly surprised that the Create Note action is Bear 2 aware. You guys really thought of everything! :pray:
PPS. I did have to make one change to the shortcut, since I had used the Apple-supplied Create Bear Note. As others have said, I wish we could get Apple to put some “caution tape” around that.
