Cursor jumps ahead after pasting a markdown link
Testing version: 2.0 (10699)
What were you doing: Pasted a markdown link
What feature did you use: Bear editor
What happened: Cursor jumped ahead to many subsequent lines forward
What did you expect to happen: Cursor should stay at the position at the end of the pasted URL.
This might sounds odd but, if you reboot your device, you get the same pasting issue?
Rebooting didn’t fix it. Still see the same issue.
Thanks, can you please try to turn off the smart punctuation in iOS preferences > general > keyboard
No, disabling that doesn’t fix it.
