Testing version: Version 2.0 (11417)
What were you doing: Adding a header (bug appears on both MacOS and iOS)
What feature did you use: header icon (with new icon number)
What happened: The cursor appears above the header text (I’ve included a screenshot with arrow pointing toward the position.
What did you expect to happen: I expect the cursor to be positioned level with the text
