Cursor positioning bugs
ios, 2.0 (10670)
Inserting a separator, after a blank line following a code block
BIU keyboard > separator
cursor hidden behind keyboard
cursor above keyboard
testing w/
testing.txt (484 Bytes)
( after the code block, add a blank line, then insert separator)
See screen capture:
Another trigger for the cursor positioning bug is to use the keyboard to add a link but hit cancel afterwards.
