[data loss] Closing a note in a separate window may not save most recent changes
Testing version: 2.0 (10688)
What were you doing: Editing a note in a separate window, then closing the note when I was done writing.
What feature did you use: Note editing
What happened: The most recent changes were unsaved and therefore lost
What did you expect to happen: Changes to the note should be saved so that data loss does not occur.
An easy way to test this is to create a new note in a separate window (⌥⌘N), type something quickly, then close the window with ⌘W. When viewing the newly created note in the main app window, its contents will be empty, with whatever you quickly typed gone.
Thanks for this bug report. It’s indeed quite bad.
Hello there,
we have found and fixed the issue, next release will contains the fix :slight_smile:
Best.
