Hi! I code a lot and I like to document many of the things I do with screenshots! I like to break things down into steps and substeps so that I can easily refer to my notes in the future. Currently, Panda only increments numbered lists in numbers and starts again at 1 when you create a sublist, which can be visually confusing when implementing larger screenshots creating large gaps between steps. It would be helpful to have it broken down differently, such as the way Word/Onenote handles their numbered lists.
This would be incredibly useful for me, I Bear for Class notes in college and this is definitely an issue I have ran into, in the same vein, bullet points for “-” and “*” being exactly the same can create confusion if importing into bear from somewhere else.
Also for anyone who deals with this issue a lot @lmf I would recommend using a combination of Headers, numbers, and bullet points. These combined with indents have helped me a lot.
