Does folding/unfolding all headers make sense in that way?
To justify the question here two screenshots:
Does the result in first screenshot makes sense? Is there anybody who just wants to see title of the note in the note itself?
My suggestion: if the highest present header level appears just one time in the note then do not fold it but just all heading beginning from the levels below
Another criticism: The place of the commands provokes the misunderstanding that the command will be applied just on the clicked header and its subheaders. Maybe the notes menu would be a better place whereas the commands in the headers menu could indeed be related to just this header and its subheaders
If I fold a header, I want all text, subordinate headers, and their text to be hidden with the header still visible.
Example:
Header 1
Header 2a
Example text.
Header 3
More text.
Header 2b
Even more text
Header 2a would be folded as:
Header 1
Header 2a
Header 2b
Even more text.
I agree with the OP.
Because the note title and header are essentially the same in Bear every header other than the note title/header should fold. Otherwise, all you’re left with is the note title - which seems pointless.
