Easily put double square brackets around selected text
Hi!
I selected a word by simply double-clicking on it and then typed alt+5 for a squared bracket to see how panda would interpret it. For my pleasure it put the square bracket to the left and to the right of the word. my hope was that a second alt+5 would create a second square bracket about the word so that a wiki-link to a new note could be created. But unfortunately just the first bracket was removed.
Hi there,
Linking to other notes (and ways to trigger this) is not something we’re focusing on in Panda at the minute.
This is as Panda is just a test Editor for Bear. It is separate from Bear for now and doesn’t include some of Bear’s other key features.
Regardless, thank you for the feedback, and for taking the time to post.
