I want to be able to issue a command prompt and use the “/” button like Notion and Craft to call out a menu.
I hope it can be compatible with the Chinese sign “、”
Hi there,
Thank you for the feedback, but this most likely will not be implemented into Bear.
This is as we already currently have a new Styles bar (macOS, which can also be accessed via shortcuts) and a custom keyboard (iOS) to display tools.
Also the slash sign / is already used for creating italics in Bear.
Regardless, i’ll pass the suggestion onto the development and design team to consider when moving forward.
