Editor Setting Missing in 2.0?
Sorry if I am missing something here, particularly if it is obvious, but there does not seem to be an Editor tab in the settings menu. (There is also no Sync or Bear Pro tabs, but that makes sense to me.) Also, is there a way to change the font in the Notes List? It is different that in my current set up, as the font seems to be smaller.
Thanks for all the hard work.
Font size can be adjusted via ⌘ + or ⌘ –. The editor panel is coming, prob by when iOS beta would be released.
Great. Thank you for the quick response. Just wanted to make sure I did not have a bug that should be reported.
