What were you doing: clicking around various parts of the welcome document while opening emoji picker with cmd-ctrl-space
What feature did you use: n/a
What happened: the emoji picker often does not appear when invoked. Most often it finally appears after clicking the mouse on a different part of the document. It doesn’t seem predictable. Similarly, when you pick an emoji, it doesn’t appear right away and instead usually appears around where you click your mouse.
What did you expect to happen: the emoji picker opening immediately and emoji that are picked show up where the cursor is in the document
When I submitted this I’d restarted Panda a few times and it was replicable. However I cannot get it to replicate today, except for a slight delay after picking the emoji and when it appears in the document. This means if you click elsewhere immediately after picking an emoji, the emoji will appear where you clicked.
This is identical to behavior in other apps (Notes, Day One, Sublime), so perhaps there’s nothing to be done.
