What were you doing: Highlighting (====) emojis and text inside a note.
What feature did you use: Pasted emoji (using Raycast) and tried to highlight it using markdown’s symbols.
What happened: After pressing enter (or going to the next line) so that markdown preview would render, the text (and emoji) did not get highlighted, instead stayed with the symbols (====)
What did you expect to happen: Expected the text as well as the emoji to be highlighted.
Going back to it, I suspect that might be due to how markdown handles logic, so in this case correcting it to where the symbols don’t overlap would solve the issue for example:
==**🤝 Note**==
appears to render fine. That means this might have been a mistake on my end from the beginning, but please correct me if I’m wrong.
