Testing version: Bear alpha
What were you doing:Adding rows to my table
What feature did you use:Tables
What happened:A row was added before the selected row.
What did you expect to happen:A row to be expected following the selected row.
Hello there, thank you for the feedback!
May I ask you have added the row to the table? Currently Bear alpha has 2 ways of adding a row:
Is the behaviour you are experiencing different from this?
Yes. I chose the after option and it was inserted before. It was a very small table 2* 2 and the first row was selected. The new row was inserted at the top of the table and I had used the insert after option.
Thank you very much! We will investigate the issue!
