Exporting single note results in all notes within tag group exported
Testing version: Version 2.0 (9652)
What were you doing: I exported one note from the note’s upper right dots menu to PDF, docx and HTML.
What feature did you use: The single note export command in the dot menu of the note I wanted to export.
What happened: I was in the Untagged list. The list had 3 notes. All three were exported. When I changed tag list and exported a random note in that other tag list, it worked fine. When I changed back to the untagged list, it now also worked as expected.
What did you expect to happen: Only the note I was in, using the note’s 3-dot menu, should have exported.
Good catch! This bug will be fixed with the next update.
