Feature request: Customized Output
Hi! It would be great if Bear had a option to customize the output. I’m thinking specially on the pdf and html options. I work with themes on the app, so when I save it on those formats the style changes too much. It would be awesome to personalize it completely but if it’s too much work, to be compatible with themes would be ok.
Thank you!
Hello there,
when the new editor will be out, we plan to allow export using the current theme/typography settings, this should help you in customizing your exports :slight_smile:
Best.
I completely agree, this would be great especially with tools such as footnotes coming, the ability to have more control over how exports look would be a complete game changer, whether it be in being able to create profiles, or select from some custom themes.
