The way I organize my notes in Bear is that I have a tag for each of my projects, and these projects tags are sub-tags divided into different tags (depending on the project content, if its active, archived, etc…) So it would be great if it was possible to drag tags inside one another in the sidebar.
Dragging is not possible bout you could select a given tag and all its correspondending notes. Then just rename them so that they are moved under another tag
