I would like to share personal experience on new bear editor and it is much more readable with codes and text
- For the code block, indention (
tab
) uses 4 spaces( ) instead of tab (\t) - Support new front such as Hack Font (https://sourcefoundry.org/hack/) for code block or inline code
- Support Merge Notes
- Support Manual Sort <- this is very important to writing articles/books/chapters
- More synxtax highlight language supports
- A tag manager that allows to manually create the tag. Currently, there must be a least one before have a tag exist
- A new sector called “Untagged” can be called “Inbox” which can optionally set to default and all the untagged notes will be there. It can be clear to collect some scrappy.
