test version 版本2.0 (10084)
Bear2 feedback from Shrektan
2023年1月9日 22:21
#Bear 2/feedback#
版本2.0 (10084)
Sorry that my account is new, so I can’t post with more than two pictures.
So I have to put some source links of my screenshots in raw formats.
Most dark themes can’t display Code clearly
Description and Example
For example, the code import os
looks at different dark themes.
It’s challenging to separate the code segment from the normal text.
Panic
https://shrektan.com/img/bear2-feedback/bear2-feedback1.png
Dark Graphite
https://shrektan.com/img/bear2-feedback/bear2-feedback2.png
Toothpaste
https://shrektan.com/img/bear2-feedback/bear2-feedback3.png
Suggestion
Make the code background color more vivid for dark themes.
The menu “move Completed to button” in the styles bar is always grey
However, the menu on the status bar is usable.
Styles Bar: the move completed to the bottom is always grey
Status Bar: the name is different. Now it’s “Move Done to Bottom.” In addition, it’s not grey.
The numeric list displays precisely the same for different levels. Can it be different?
https://shrektan.com/img/bear2-feedback/bear2-feedback6.png
