Folded section contents in Table of Contents
Testing version: 10084
What were you doing: Folding H3 Header with section content
What feature did you use: Folding
What happened: Using the new table of contents, it appears that if a section is ‘folded’ under it’s corresponding header (H1, H2, etc.) the content gets stuffed into the ToC list under the header.
What did you expect to happen: ToC looks cluttered af when section is closed or ‘folded’. Not sure if a bug of intended feature.
Probably intended, but I’m also not a fan of it.
I really cannot imagine that this is intended. That must be a bug
Yes, this is definitely a bug :sweat_smile:
Thanks for reporting.
