Footnote and reference not linked
Testing version: macOS, Bear 2 beta (build 10688)
What were you doing: Navigating from an inline reference to a supposedly linked footnote.
What feature did you use: footnote
What happened: A new footnote gets added automatically. (But even that isn’t actually linked: clicking the inline reference will, again and again, insert a new footnote.
What did you expect to happen: Inline reference and footnote should be linked.
Reproducible examples
This bug only happens when the reference starts with an upper-case letter. For example, the following works perfectly fine
This is an inline reference[^note].
[^note]: And it works fine.
but the following pair is not linked
This is an inline reference[^Note], and the only difference
is `N` vs `n`.
[^Note]: Not linked anymore.
Hello there,
thank you for the feedback! We’ve fixed the bug in the internal version and the issue should be solved in the next version update :slight_smile:
Best.
