Footnotes ordering
Testing version: 2.0 9735
What were you doing: Inserting a footnote
What feature did you use: Footnotes
What happened: I inserted a footnote above some other footnotes. Instead of renumbering to keep in document order, it kept it out of order.
Additionally, the footnote came in under a tag that was at the bottom of the document, not grouped with the rest of the footnotes.
What did you expect to happen: I expected the footnotes to re-number so that the first footnote would be the closest to the top of the document.
I also expected that all footnotes would be grouped together at the bottom of the document.
yes, we want to introduce footnotes re-numbering following your expectations.
This is supposed to happen unless you wrote something else below the footnotes.
