Header behavior
Testing version: 1.0 (1949)
What were you doing:Changing a list item to a header (H2)
What feature did you use: Format/Headers/Header2
What happened:The selected text changed to a header, but all the text in the list below it was changed to code. Backspacing over the asterisk before trying to change the line to a header removed the (display) formatting from the list, although the plain text remained.
What did you expect to happen: I expected the selected line to change to a header and the remainder of the list to remain as it was.
