Testing version: 2.0 (10641)
What were you doing: Menu problems
What feature did you use: Header, Export
What happened: no function, frozen screen
What did you expect to happen: the function that should be given
Something very odd is happening here. Regarding Bug 1, Bear froze before or after you choose one export option?
Bug 2, I don’t understand how you managed to hope menu in the second screenshot without having an header button on screen. Do you mind sharing which iOS release and iPhone model you are using?
Hi Danilo,
sorry for the late answer.
I am very satisfied with the new version! Awesome job!
Thanks for your help!
Best Regards
Bernd
