Hovering pointer over tables
Testing version: 1.0 (362)
What were you doing: Working with a table containing links
What feature did you use: Held mouse pointer over text in the table.
What happened: The pointer icon stayed the same.
What did you expect to happen: The pointer icon should change to the “hand with extended index finger” icon when hovering over links, and the I-beam icon when hovering over other text, like it does elsewhere. This behaviour already happens outside of tables.
