Does Bear 2 support page breaks? If so, how do I do it?
No, we donât have page break support.
I just came looking for this feature as well. I often export notes as PDFs to share, and it would be great to be able to drop in a simple page break instead of having to add extra blank lines to my notes, then preview, then adjust, preview, adjust, etc. Itâs a pretty miserable UX and leaves me with decent PDFs, but crappy looking Bear notes with random spacing.
@Ziad I agree, itâs definitely needed.
@trix180 could you please add this to a âfuture enhancementsâ list?
A page break in ulysses is done on export by interpreting the separator line as such a break. It was several times said that after 2.0 export will be improved. Maybe ulysses feature could be considered
@krssno On the other hand, many users may do not like it (separator as page break as they use it for other purpose). In my experience, Ulysses export depends on selected print template - some consider e.g. h1 or h2 heading to always start on new page and some donât etc. I believe this functionality - specific for export - should be responsibility of export template - not something generally inherent to note markdown syntax.
Dâaccord! Pagebreaking by header level is ideal. Nevertheless taking the separator as sign for pagebreaks on export can be meaningful in some scenarios not only but especially as it is independent from the export style theme
Totally agree on the page break. The app âNOTEBOOKSâ has both a line separator and the ability to enter a page break. VERY USEFUL! I also export Bear notes as PDFs all the time and being able to control the pagination is critical. Thank you!
In the 1960s, ASCII 12 (Form Feed) was created for a page break. And here we are, wishing we had it now. I suppose 
would be a bit too obscure for millennials.
Would increasing the number of dashes or underscores be too obscure? For example:
Line separator after this line.
Page break after this line.
