How to get side bar to show?
Hi all,
In Bear app, you can view the Show tags, notes and editor view. Does this exist in Panda yet? If so, how to enable it if preferences are greyed out. I’ve seen it in screenshots and demos.
Thanks
There is no sidebar which could be shown. Panda is just the editor that will be implemented into bear 2.0 and was meant as throw away app after testing the editor. Nevertheless it was announced that panda maybe or probably will be released as standalone app which handles file based documents. If the further development of panda should go in that direction you can expect to see someday a sidebar
bummer, ok, thanks.
Thanks for the reply.
Be patient! :wink:
Once the implementation into bear is finished you will have the panda editor and all other features from bear.
See here a preview!
