Images can't be copied between notes
Testing version: 1.0 (615)
What were you doing: Copy an image from one bear window to another
What feature did you use: Edit → Copy on a image
What happened: A white image seemed to be copied, if you reopen the new file, the markdown text is shown
What did you expect to happen: The image is copied and shown as it looked in the first place
Hello!
the new update should have solved this issue, thanks again for the report.
Best.
