Import from DayOne in Bear 2
2.0 (10641)
I was testing the import from DayOne feature. I tried on iPad and on Mac. iPad has the option to import from DayOne and Mac does not, at the moment.
Importing a JSON export from DayOne
On iPad, I went to settings → import & export → import from and selected DayOne and then ‘start import’ and selected the DayOne zip. Importing began, but immediately a “error imported notes; unknown error happened” popped up.
I expected the DayOne entries to be imported into Bear 2.
Sorry the confusion but the DayOne importer will be removed from the iPadOS/iOS version too. Eventually will be rewritten to work with the new editor.
Understood. Thank you!
