Inconsistent results when repeating format commands to remove nested formatting
Panda 1.0 (415), Catalina 10.15.4
There is some inconsistency when repeating format command to remove nested formatting which were previously applied.
Example 1: select text and press Cmd+IB (italic, bold). Now press Cmd+I again to remove italic formatting: this works great, italic formatting is removed.
Example 2: select text and press Cmd+BI (bold, italic). Now press Cmd+B again to remove bold formatting: nothing happens even if you press Cmd+B repeatedly.
Example 3: select text and press Cmd+BU (bold, underline). Now press Cmd+B again to remove bold formatting: the markdown indicators are swapped instead. You should press Cmd+B twice to remove bold formatting.
Example 4: select text and press Cmd+L (list). Now press Shift+Cmd+T (quote). Pressing Shift+Cmd+T again does nothing. Pressing Cmd+L again removes all formatting (!).
