Testing version: 1563
What were you doing: Finished a code block, started a numbered list
What feature did you use: code block markdown and then a numbered list
What happened: with multiple number list items below the code block, I indented the numbered items to match the indentation from above the code block. When I went to indent the first numbered item directly below the code block, it indented the text, then another tab put it inside what looks like a code block, but the code block does not show the markdown syntax ```
What did you expect to happen: I expected the numbered item to indent just as the ones below it. see video attached
